Author Topic: Puzzled over Lack of power  (Read 3206 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« on: 20 April 2012, 19:35 »
I have a 1.8t aum with a R-teck remap, which does not feel as quick as it used too. I have changed pretty much all the usual stuff, like air filter to a pipercross panel, new coil packs, new maf, new N75, changed the diverter valve to a forge 007, replaced breather hoses and others with silicone ones, have a new silicone tip, new 02 censors. Recently had a service which also included a new fuel filter, and replacement thermostat, and a repair to the air pump changing the rivets to bolts.
All this, and a few other things done to it (that would not effect power like new bushes and discs and pads) over the past year which have cleared the infamous 17705 code, (which I have been free of for some time now  :smiley:) but there is certainly a lack of power still  :sad: It is a bit better than stock, but not what it used to feel like when the remap was running good. I have no codes coming up on my code reader, so I am at a loss to think what the lack of power could be. Sometimes it feels like some of the power comes back every other day, not full power, but an improvement nonetheless, but that magical remap spark seems to of gone!
I have heard that a new stainless steal exhaust like a miltek may help, but as there are no leaks in the exhaust, is it necessary to change to get the power back?
Does anyone have any suggestions as to things that could be causing the lack of remap power? Could the injectors need changing? Any suggestions I would be grateful of, thanks.
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline daz veedub
  • Operation 1.8t bolf
Re: Puzzled over Lack of power
« Reply #1 on: 20 April 2012, 19:46 »
any boost leaks any where
« Reply #2 on: 20 April 2012, 19:54 »
I can't find any, or hear any at all. I did have a look at the pipe that goes on to the pancake pipe about 3 months ago, and that was fine, no splits, and I haven't had the 17705 code for a while now
Offline daz veedub
« Reply #3 on: 20 April 2012, 19:56 »
ones under inlet manifold are a commen 1 have u checked them
« Reply #4 on: 20 April 2012, 19:58 »
I have replaced all of them, even the "L" shaped one that comes out of the sump
Offline navmk4gti
« Reply #5 on: 20 April 2012, 20:02 »
Get a boost gauge fitted and check the psi your hitting  :wink: that will let you see if there is a
Leak or its just your head :lipsrsealed:
Offline cullygti
« Reply #6 on: 20 April 2012, 20:06 »
sounds like a leak somewhere i could definately feel a diiference from before and after i fixed a leaking pipe its like night and day
« Reply #7 on: 20 April 2012, 20:08 »
Thanks, sounds like a good idea, so I will go and see what I can find on ebay. I am certain it is less power than it used to be, as the torque is no where like it used to be. there is definitely a lack of power  :sad:
« Reply #8 on: 20 April 2012, 20:12 »
After I had the service a little while ago, my mechanic found a split in the tip, and he temporarily fixed it until I bought a new silicone tip. The difference was easily noticed after he had temporarily fixed it, but after he had put the new one on the power has seemed to come and go a bit.
Offline cullygti
« Reply #9 on: 20 April 2012, 20:17 »
strange that as he fitted it correctly its just if there was power before he changed it and then dropped summat got to be checked in and around that area imo just a thought mate
