Author Topic: Anyone know about the ASZ (130 PD) engine timing that could advise?  (Read 10003 times)
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
Briskoda forum is rubbish and i know all you guys are good help  :smiley:
I changed my timing belt the other week and while doing it i left slack on the cam w pump crank side and tensioned it which i know ballsed it up because i tried turning it over and it wouldnt start i then took the glow plug out of cyl 1 with a metal rod found top dead centre, removed the pully wheel off the cam and moved the cams back with a wrench replaced the pully and started ok.
I have slight poor mpg when driving eco style and it used to pull hard from 1.5k but it seems to be slightly weeker now and i realy have to drive it hard to 4k to feel satisfied if you know what i mean where as before it used to pull hard from low rpm and i used to change at 3k when wanting to get away.
Is there any markings on engine casing crank pully and under the cam pully and pully it self so i can go by to set it back up to default kind of thing...?
Thanks for your help guys
« Last Edit: 20 April 2012, 14:56 by G60GTI16V »
Offline littco
Re: Anyone know about the ASZ engine timing that could help?
« Reply #1 on: 20 April 2012, 13:11 »
Flywheel has a mark at tdc in the little window on top of the bell housing by the gear shift. Put that mark in the middle and the you need to lock the cam pulley in place through one of the the eye holes at about 2 o'clock. There may even be a locking pin hole on the crank pulley as well.
Offline G60GTI16V
Offline G60GTI16V
« Reply #3 on: 20 April 2012, 14:15 »
can some one tell me when looking at the pulley turning the cam clockwise or anti-clockwise is advance and retard? il have a play at the weekend then see if i can get it spot on.
im guessing clockwise is advance right?
« Last Edit: 20 April 2012, 15:01 by G60GTI16V »
Offline old_n07
Get a PD timing kit and fit lock everything out properly with the marks on the crank and the cam pulley :afro:
If the peg won't easily go into the hole on the cam pulley loosen the three blots off and turn the pulley so it does, the timing should be spot on then.
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline G60GTI16V
Top info thanks this is what i was after  :smiley:
Got it running spot on now i get over 60mpg at 60mph on the motorway  :wink:
Offline old_n07
Did the cam pulley need adjusting then?
Offline Steve_PD
Am going to steal that guide for the maintenance section Neil :afro:
Offline old_n07
No problem :afro:
