Author Topic: mayo build up, Not the norm  (Read 4662 times)
Offline shelaghmk3gti
Re: mayo build up, Not the norm
« Reply #10 on: 22 April 2012, 10:53 »
omg those pics bring back terrible memories  :cry: was the head on my mk3 .. tho wasnt quite as bad as that mess
Offline Chris#101
« Reply #11 on: 22 April 2012, 11:51 »
The car was servieced less than 700 miles ago but im going to whip the sump off to double check.
I only drive a 4 mile round trip to work and back every day then + what ever I do in the evenings!?
On closer inspection one of the pipes going to my oil catch can had completely kinked  :undecided: so Ive rerouted the pipe work, would this of had any effect?
Since wiping the stick and and filler cap clean, Ive only had a very slight dusting of gunk!? no where near as bad as before
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline clipperjay
« Reply #12 on: 22 April 2012, 12:22 »
Well thats good news I'm guessing it must have been condensation and a kinked pipe work to produce that much mayo! wiping it all away and changing the oil must defo fix it, even dropping sump to clean it all out will fix it too.
Glad its all sorted panick over  :smiley:
Offline gedbedhead
« Reply #13 on: 28 April 2012, 21:02 »
oil cooler.
