Author Topic: any1 know what this earth is for?  (Read 2382 times)
Offline off_the_cuff
« on: 19 April 2012, 16:32 »
so i've been doing a bit of searching today to see why my cars getting a spark and fuel but not firing, all my earths are fine apart from this 1, any1 know what its for and if its important? was tucked down behind scuttle panel :S
Offline Dogbot
Re: any1 know what this earth is for?
« Reply #1 on: 19 April 2012, 17:00 »
yup.......
goes to the bonnet hinge.... almost every mk3 i've seen its either broken or missing.....
« Reply #2 on: 19 April 2012, 17:03 »
is it an important earth?
Offline Dogbot
« Reply #3 on: 19 April 2012, 17:06 »
err....... mine was broke so i threw it in the bin.....
i dont think it is as mine runs just fine without it,
but im prepared to get flamed for being wrong......
Offline liva2704
« Reply #4 on: 19 April 2012, 17:08 »
Yeah i ditched mine also,i cant really see a need for it why earth body to body.I may also be wrong unless its got something to do with the heated washer jets?
« Reply #5 on: 19 April 2012, 17:13 »
is there any other earths to check? apart from under battery and front of engine?
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #6 on: 19 April 2012, 17:31 »
The bonnet to body earth is there to reduce static noise through your radio I beleive, so not that important.
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #7 on: 19 April 2012, 18:00 »
Correct its just a bonnet earth strap, it always corrodes and snaps mostly at bonnet end, not really needed anyway so remove and forget it :wink:
Offline gasketface
« Reply #8 on: 19 April 2012, 18:10 »
Is it not for the heated washers then ?.
« Reply #9 on: 19 April 2012, 18:16 »
should i check anywhere else?
