Author Topic: Intermittent Wiper not working  (Read 6247 times)
Offline moby dick
« on: 19 April 2012, 10:33 »
The intermittent wiper function on my Gti has stopped working. The regular wipers work fine but the intermittent function just wont work. The rear wiper works fine as well. Any helpful suggestions welcomed.
\\\"I spent a lot of money on booze, birds and fast cars. The rest I just squandered\\\" George Best
Offline clipperjay
Re: Intermittent Wiper not working
« Reply #1 on: 19 April 2012, 12:38 »
Just search wipers not working but money is on the Relay some relays arent right and the speeds are two instead of three.
Offline devilscaff
  • allways up for alaugh
« Reply #2 on: 19 April 2012, 20:35 »
mine was the same I bought a replacement stalk,works fine now the connections were all corroded
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 20 April 2012, 19:54 »
Relay is what I would guess at - No 19 in the fusebox...
Time to upgrade to a No99....
For More Info Click To See;
Offline clipperjay
« Reply #4 on: 20 April 2012, 20:12 »
Can I get a flake with that  :drool:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #5 on: 20 April 2012, 20:56 »
 :laugh: :laugh: :laugh: :laugh: :laugh:
Offline moby dick
« Reply #6 on: 21 April 2012, 06:35 »
Thanks Guys, I'll check out the relay first and then go far a replacement stalk. Mr Whippy says Hi.
Offline moby dick
« Reply #7 on: 09 May 2012, 12:48 »
Just fitted a new relay and that hasn't cured the problem. Hey ho, new stalk I guess
Offline walchy01
« Reply #8 on: 09 May 2012, 20:40 »
What's a 99 give you :laugh:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 09 May 2012, 20:52 »
Quote
So Simple It Is A "Plug-N-Play" Item.
BRILLIANT ITEM... Changes Your Useless Single Swipe Every 10 Seconds - Front Intermittent Wiper, Into A Fully Programmable One Which You Can Change At The Flick Of A Wiper Arm Switch...
I Have Fitted These To All My Current & Previous MK2 Golf's & My Audi Coupe...
It Makes A World Of Difference When Driving In Spray/Drizzle/Rain etc...
How Does It Work?  To set the time you will need to switch on the ignition, set the wipers to the intermittent setting then count the number of seconds you want then turn the wipers off, turn the wipers on again and that's it set. You can reset the time delay again by turning the wipers off and on again.
