Author Topic: GTi 8v cutting out @ 94 degrees  (Read 1603 times)
Offline markswan
« on: 18 April 2012, 15:03 »
Hello, I have searched and searched however I'm not getting any closer to an answer..
Basically my 8v cuts out bob on 94 degrees, if you let it cool you can restart it,
its just had a new crank case sensor, coil pack leads and plugs,
I'm at wits end over it.
If you disconnect the oil temp sensor it runs but still cuts off at about the same temp, so it cant be the ecu thats cutting it off
help please
Offline harlemex
Re: GTi 8v cutting out @ 94 degrees
« Reply #1 on: 18 April 2012, 16:34 »
try ecu coolant sensor.
Offline wakeskater
  • H20 PHW MK3 16V DAILY ,,,MK1 16V PROJECT,,
« Reply #2 on: 18 April 2012, 19:59 »
i bet its a cheap crank sensor  i had one that did it at  88 ish
Offline markswan
« Reply #3 on: 18 April 2012, 22:50 »
sounds ominous lol
Offline javalin
« Reply #4 on: 19 April 2012, 09:29 »
get the one from GSF - a few people here including me run it and its fine.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline markswan
« Reply #5 on: 19 April 2012, 18:41 »
noticed today the ecu relay is running really hot.. as in burnt my finger.... its got no plastic on it either...
im hoping if i pop one in it might be right..
just hope smith Knight fay have one in
