Author Topic: mk3 golf 16v water/radiator issue?  (Read 2983 times)
Offline Djmac
« on: 18 April 2012, 09:02 »
Hi all, have some issues with my mk3 16v gti! The car is getting warm pretty quickly and spilling its header tank, i put water in, yet the  water light flashes on my dash! some times when i just start the car the water temp says its at normal temp and when i take it for a little spin out the guage reaches its peak temp?
is it a thermstat issue? Coulkd anyone help?
Offline tweed
Re: mk3 golf 16v water/radiator issue?
« Reply #1 on: 18 April 2012, 09:21 »
First thing to check is start cold and see if bottom hose gets warm.
I think your water pump is f**ked or you have a bad blockage.
For sake of engine don't drive
Offline mad4vws
« Reply #2 on: 18 April 2012, 11:57 »
check all water pipes ,you might have a blockage or air lock if all else fails change waterpump . :wink: :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline javalin
« Reply #3 on: 18 April 2012, 13:09 »
is it overheating?  If so would be a airlock, or thermostat stuck issue.  If not, suspect header tank cap - good ones are blue.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Djmac
« Reply #4 on: 18 April 2012, 13:47 »
its just had a new water pump! could the mechanic have done something wrong! what more can i do to check?
And yeh james it is overheating... i see steam coming out of my bonnet, ive not drove it since i read these comments!
« Reply #5 on: 18 April 2012, 13:48 »
Could be a head gasket issue if it is building that much pressure.
Offline javalin
« Reply #6 on: 18 April 2012, 13:53 »
doubt its waterpump, would suspect blockage/thermostat/airleak personally, or as Wayne says possibly headgasket.
James
Offline Djmac
« Reply #7 on: 18 April 2012, 14:15 »
thanks for the advise guys! if the head gaskets just gone, will there be signs of white residue straight under the oil fill cap, or is that after a while? i havnt checked mine yet, what other signs could i look out for! anyway of testing if the thermostat is working without stripping?
Offline javalin
« Reply #8 on: 18 April 2012, 14:43 »
If headgasket gone = water in oil, or oil in water, or water out of the exhaust etc.  A garage can test for these.
Thermostat - your radiator will not warm up if stuck shut, once water temp is 90c. (feel temps of top and bottom hoses)
James
Offline Djmac
« Reply #9 on: 19 April 2012, 15:27 »
havin a go with the car now... ive topped the water up as it was low so the temp light is off... ive ran it for 20 mins and the bottom and top hose is warm! everything seems ok now topped up, just last time i did this it spilled the header tank?
« Last Edit: 19 April 2012, 16:11 by Djmac »
