Author Topic: ways to drain & flush power steering system,  (Read 1278 times)
Offline Dogbot
« on: 17 April 2012, 12:54 »
Now, I have made a grave error....
whilst finishing up the wifes lupo project for the road I have made a proper noob mistake and used dextron III type mineral power steering fluid, only 600 miles at a push have past & i have since learned my error, I have the correct fluid on its way but my question remains how would you flush the system,
I was going to remove the return pipe from the pump and run the system, as the fluid drops i intend to fill it up as it runs through with the correct fluid so that it flushes throu, i also intend to have someone turn from lock to lock with the wheels jacked up to get all the fluid through, once coming through clean & green I would re attch the return pipe and set about removing any air.....
Anyone have a better way??
Hopefully ive not caused the seals to be damaged to badly... no leaks at present....
Any thoughts appreciated... and yes I know im a muppet of epic proprtions!!
Offline topher
  • Administrator
  • fully functioning
Re: ways to drain & flush power steering system,
« Reply #1 on: 17 April 2012, 12:56 »
suck as much as you can out of the reservoir first to minimise the mixing, other than that your plan sounds about right.
Offline Dogbot
« Reply #2 on: 17 April 2012, 12:59 »
Sweeeeeeeeet..... cheers dude.....
you see most of the time I have a good idea of what im doing..... there are these brain fart moments that haunt me lmao
thankyou very much
