Author Topic: brake stop  (Read 2055 times)
Offline dj g
  • vw gals
brake stop
« on: 03 June 2005, 00:58 »
I'm having more probs with my cab had it tuned wicked :cool: but then my exhaust was blowing now had the fixed :grin: but now it cuts out when i have to brake quickly :cry:some one please help getting bored now :laugh:
Offline gibby
Re: brake stop
« Reply #1 on: 03 June 2005, 01:01 »
I think you might need to explain a bit more hun.  :smiley:
......now officially dubless.
Offline dj g
  • vw gals
Re: brake stop
« Reply #2 on: 04 June 2005, 20:46 »
when i put my foot on the gas it seems like the car is nit moving any faster and then it just cuts out it also cuts out when i brake quick. :shocked:
when i start up loads of white smoke. :undecided:
i noticed today that it got worse after i washed the car water coming in passenger foot well and everywhere else i might add :cry:
Offline BobbyT
Re: brake stop
« Reply #3 on: 04 June 2005, 20:56 »
not sure bro, are using coolent? white smoke could be your head gasket?? :undecided:
Offline dj g
  • vw gals
Re: brake stop
« Reply #4 on: 04 June 2005, 23:30 »
head gasket just been done 2 months ago and smoke only when i start up first thing
 :embarassed:
Dinky
Re: brake stop
« Reply #5 on: 05 June 2005, 21:34 »
wen mine wasnt pullin wen i accelrated,turned out to b my clutch..your "biting point" changed any? like havin to raise you clutch higher than normal?
check that you car is able to drain off water properly..no gunk blockin up your drainage holes..fixed mine..
Dinx :kiss:
Offline BobbyT
Re: brake stop
« Reply #6 on: 05 June 2005, 21:36 »
 :embarassed:
did you use a good garage? did they skim the head?  :undecided:
Offline dj g
  • vw gals
Re: brake stop
« Reply #7 on: 07 June 2005, 09:53 »
 :embarassed:
not to sure about the skimming.
yes i do have to left the clutch more
Dinky
Re: brake stop
« Reply #8 on: 07 June 2005, 23:37 »
check both ur head n clutch hun..i gotta agree with funky on smoke but not on ya biting point,cos i doubt it wud affect that.. :undecided: u aint havin much luck hunny...
Dinx :kiss:
Offline BobbyT
Re: brake stop
« Reply #9 on: 08 June 2005, 12:20 »
could be clutch and the head??  :undecided:  :tongue:
