Author Topic: MK4 GTI 2.0L fault codes  (Read 1463 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 16 April 2012, 20:10 »
Evening,  My sister is down on holiday with her MK4,  with complaints of bad economy and MIL Light!
Did a fault code scan  -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
        P0134 - 35-10 - - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
        P1128 - 35-00 - -
16555 - Fuel Trim; Bank 1: System Too Lean
        P0171 - 35-00 - -
16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
        P0139 - 35-10 - - - Intermittent
Im inclined to replace Number 1 sensor,  assuming the other faults are caused by this, im not sure about the last fault though.
Any other ideas than number 1 02 sensor here?   Cheers.  :smiley:
« Last Edit: 16 April 2012, 20:28 by Rmachines »
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Rmachines
Re: MK4 GTI 2.0L fault codes
« Reply #1 on: 18 April 2012, 22:23 »
Incase anyone wonders - Yes it was the number 1 02 sensor.
