Author Topic: New mk2 owner running issues  (Read 4104 times)
Offline apie2004
Re: New mk2 owner running issues
« Reply #10 on: 18 April 2012, 11:57 »
In the fuel tank, there is an access hole in the right hand side of the boot with 3 screws holding the cover in place
Offline mush
« Reply #11 on: 19 April 2012, 12:07 »
cheers apie
ive brought the new lifter pump (smaller than i thought) ok so ive had real trouble trying to unscrew
the pump however its stuck tight...... do you have any tips on removing? ive tried a thin bit of wood and
hammer and tried tapping it but no joy. (dont want to damage it)
i know this sounds stupid but would heating it up with a hair dryer work? obvouisly not a heat gun.
theres no way of getting wd40 in there either.
also is the lifter part under where i'm trying to get to? sorry for all the question but i need to get this right.
MK2 golf 16v :-)
Offline apie2004
« Reply #12 on: 20 April 2012, 16:12 »
Have you got the lift pump and fuel sender out of the tank or is this before that? Mine was tight but could just about undo it by hand
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #13 on: 20 April 2012, 16:48 »
can you get an oil wrench on it, maybe the type with the chain? its a plastic lid on a plastic tank so it should come loose easily enough.
Offline mush
« Reply #14 on: 20 April 2012, 21:32 »
Ok so I've removed the lifter pump today and found out the units not working its self. So I'm stuck now. I've tried vw for a new one and they don't do them anymore also gsf and other places. Does anyone know what the part number is so I can do a more detailed search. One golf owner not going anywhere at the moment :-/
MK2 golf 16v :-)
Offline mush
« Reply #15 on: 20 April 2012, 21:37 »
Cheers dudes the oil filter wrench worked perfectly. Was so tight
MK2 golf 16v :-)
« Reply #16 on: 20 April 2012, 22:10 »
got a lift pump sitting in the garage m8 was workng fine prior to removal if you are intested.
Offline mush
« Reply #17 on: 20 April 2012, 22:40 »
Awesome how much would you take for it? Using my blackberry so unable to see your location.
MK2 golf 16v :-)
« Reply #18 on: 20 April 2012, 22:47 »
pm sent
