Author Topic: Sticking revs/high idle  (Read 3181 times)
Offline klapwijk
« on: 16 April 2012, 11:37 »
I've just got a new Mk2 Golf. 16v KR 1989. When I start it, it revs up to 2000rpm and then very slowly goes down to 1000rpm. When I then rev it, it will stick at that rpm and then if i rev it again it will stay at that rpm. I.e if i rev it to 2000rpm the revs don't drop, then if I were to rev it to 3000rpm it won't drop. The only way to get it to drop back down is to drive off. Also in-between gear changes the revs go up to 3000rpm and stay there.
I can see that the cable isn't sticking when looking in the engine bay. I've checked for air leaks as well. I've also disconnected the ISV and the revs don't drop on idle.
Just took off the intake boot before the throttle body and checked that both butterfly valves were closed, and then started it and the revs still went up higher than normal... I then disconnected the ISV wiring and the TB wiring and the revs dropped a little bit. I have also tried a working ISV off another Golf I have and no change. Would the fact that the crankcase breather is disconnected and where the breather attaches to the air box is blanked off have anything to do with it?
Offline klapwijk
Re: Sticking revs/high idle
« Reply #1 on: 16 April 2012, 22:58 »
Any ideas?
Offline Sam
  • Sam I am
« Reply #2 on: 16 April 2012, 23:04 »
Disconect your isv wire and if she doesnt stall thats the problem, you can clean them out with carb cleaner and see if that sorts it. If not, new isv time. Otherwise it may be your throttle boddy, disconect the air inlet pipe and push the flap open and closed a couple of times to see if its stiff. If it is, again use carb cleaner to free it up and see what happens. If this doesnt work, report back  :smiley:
Offline klapwijk
« Reply #3 on: 16 April 2012, 23:23 »
Thanks for your reply, I've tried another ISV that I know works but no joy. Even if I pinch the hose that leads to the ISV it doesn't stall. So air must be getting in somehow? I've tried adjusting the idle screw to see if there is a change of idle speed, and there isn't. So I have a feeling that the idle switch is knackered. I can't see any vacuum/air leaks though. So I have no idea where the air is getting in.
