Author Topic: 2k rpm getting on my nerves  (Read 1432 times)
Offline Rain
  • forum irregular
« on: 02 June 2005, 20:18 »
having a problem with dam idle revs they keep jumping upto 2000 and sitting there for a while then coming down if i rev hard they drop normal back to 700-900 roughly but if im sitting in traffic just on the clutch the revs raise and i roll away getting on my nerves only happens when the engine is warming up its probably timing but it was timed only 2 months ago and after the car been running about 30 miniutes doesnt do it no more only seems to do it when its warming up temps between 60-80 on the mfa.
Re: 2k rpm getting on my nerves
« Reply #1 on: 03 June 2005, 13:25 »
What engine is it?  If its a Digifant then when the engine is off check the idle switch clicks when you close the throttle.  If not you need to take the top half of the airbox and the intake boot off and adjust the idel switch, its underneath the throttle body.  I found the screws were impossible to reach though so I gave it a couple of taps with a hammer till it started clicking again :grin:
While you're there clean out the throttle body till its nice n' shiny :)
Offline Rain
  • forum irregular
« Reply #2 on: 03 June 2005, 20:41 »
cheers sorted it this afternoon 8v Digi throttle body was acting up few squirts of wd40 my mate sprayed on it fixed it right up he said that when i cleaned the engine last november it dried out and just needed some lubrication guess he was right cause its running perfect not sure exactly what screw/s your on about only the one just below the throttle which is easy to get to with a long thin flat head screw driver
« Reply #3 on: 03 June 2005, 23:12 »
I'm talking about the 2 scres that hold the idle switch in place, no real way to get to em :)
Offline Rain
  • forum irregular
« Reply #4 on: 04 June 2005, 09:17 »
ok not 100% with you on that no without a closer look, ill take a look later now its all sorted :D
