Check the wires in the rubber sleeve between door and pillar as it's a common fault for these to break.
If you can hear the motor click then it is more than likely the regulator has failed,the cable frays and get jammed,ive just replaced another in my own car ,this happened on both fronts now,still have a dead one at the rear
