Author Topic: fog light problem help needed urgent!!  (Read 1173 times)
Offline vwgolf182
« on: 15 April 2012, 14:55 »
my rear fogs are not working after checking everything i can think of fuses etc.
i have tried various switches an not one of them has worked, there is power to the switch as i hav checked this also so now really stuck with what to do!!!
is it a common fault for the switches to stop working like this, or has anyone heard of this problem at all.
any help would be really appreciated
cheers
Offline Screech16v
  • MK3 20vt AGU
Re: fog light problem help needed urgent!!
« Reply #1 on: 15 April 2012, 15:10 »
Have you tried them with ignition on?
Offline vwgolf182
« Reply #2 on: 15 April 2012, 15:18 »
yeah everytime!!
Offline gasketface
« Reply #3 on: 15 April 2012, 16:31 »
Have you got the sidelights on ?.
Probably a dumb question as i have a feeling you can'nt pull the switch out unless the lights are on !!
Offline trog_nfs
« Reply #4 on: 15 April 2012, 17:07 »
Well for starters you will only have one rear fog on the drivers side.
Have you checked the bulb?
Water can get into the taillights and wreck them. I had an issue where the fog would.illuminate when i braked. Check the circuit board for corrosion
Offline gti gaz
« Reply #5 on: 15 April 2012, 20:42 »
As above had same problem last year bulb? Circuit board, easy fix if that's the problem
 Any one in cornwall lets sort more meets!!!!
