Author Topic: Front bumper help!  (Read 1930 times)
Offline Deefadog
  • Mk2 16V (November 89)
Front bumper help!
« on: 02 June 2005, 19:48 »
The front left hand side of my front bumper pulls out! I ahve had a look underneath and the metal part of the bumper is solid, the plastic part is coming away from the metal!  I can't see how it attaches to the metal part, can anyone give me the heads up on this?
Offline gti8v
Re: Front bumper help!
« Reply #1 on: 02 June 2005, 20:03 »
its held in with plastic clips that are molded into the plastic of the bumper
Offline Deefadog
« Reply #2 on: 02 June 2005, 20:22 »
Cheers mate, Can these be seen from the inside? as i can't see anything?
Offline Maltloaf
« Reply #3 on: 02 June 2005, 20:53 »
I would guess it easier to take the whole bumper off to have a look. I think it is only 4 bolts or something.
It sounds like the plastic clips on the bumper itself just need pushing back in to the bumper carrier (metal part).
Offline Deefadog
« Reply #4 on: 02 June 2005, 21:49 »
Yeah, i was goig to remove it today, but the four bolts tht i need to remove (from Haynes) looks like it the main beam that the front mount is attached to and i got a bit scared in acse the whole engine dropped :) will removing these bolts cause anything else to move?
Offline Maltloaf
« Reply #5 on: 02 June 2005, 21:55 »
I know what you mean. It can be a bit deceptive. I have not done it myself (Yet), my mate Si had a similar worry. I believe that you need to get under the car to see the bolts you need to undo, but I am not sure.
Offline Deefadog
« Reply #6 on: 02 June 2005, 22:03 »
The cars up on stilts as we speak, did the breaks today :) I can see the bolts just scared :)
cheers
Offline takethefifth
« Reply #7 on: 02 June 2005, 23:31 »
Its just the outside bolts on each side you need to undo, The centre ones hold the main cross brace thing the engine sits on in place.
They just unscrew and the bumper slides off forwards.
Offline marcogolfo
  • Freelance Web Design, Logo Design etc email me
« Reply #8 on: 03 June 2005, 00:35 »
what he said! just the outside bolts on each side good luck
« Reply #9 on: 03 June 2005, 13:19 »
PS don't drive it with the front bumper removed because the little bolts arn't strong enough.  You might need to jack up the cross member slightly to get the bolt holes to line up again though.
If it was me I'd put a jack under the engine regardless just to be safe, but you should be fine as long as you only undo the large bolts as has been said.
