Author Topic: intermittant screeching noise 1998 20v T  (Read 1119 times)
Offline SpNight
« on: 15 April 2012, 11:19 »
I have noticed this morning that my car has started making a screeching sound coming from the engine bay somewhere. It is intermittant, and carries on for about 5 - 10 seconds after I have switched the engine off. It seems to happen as I am slowing down until the point where I am stopped at a junction / set of traffic lights and then after 5-10 seconds it stops again. When I start off again it starts untill im up to about 20mph then stops again.
I get the common screeching from the starter motor on start up every now and then but this is a different noise to that.
Ive just read a couple of posts mentioning ac compressor?? But would this noise carry on after engine is switched off like mine is doing?
Had a full service about 2000 miles ago, all VAG filters and fully synthetic oil used.
The auxillary belt is showing signs of wear and it is due a cambelt change in about 5000 miles.
it has 120k on the clock.
Just need to know if its ok to drive really?
Thanks,
Offline richw911
Re: intermittant screeching noise 1998 20v T
« Reply #1 on: 15 April 2012, 11:21 »
Rad fan? Could be stuck on with faulty switch and be slighty seized  :undecided:
Offline SpNight
« Reply #2 on: 15 April 2012, 22:03 »
ive tried driving with the clima control switched off completely and the noises stop, when I switch it back on the noises start. Does this help for someone to possibly diagnose what it will be?
Offline harlemex
« Reply #3 on: 16 April 2012, 11:31 »
yup. air ac belt  :grin: :laugh:
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 16 April 2012, 11:47 »
as rich says, rad fan bearings most likely.. can't think what else might keep spinning after the engine is turned off.
Offline Dalo Harkin
« Reply #5 on: 16 April 2012, 13:11 »
SAI possibly, mine made a horrible noise and I removed it  :undecided:
Offline SpNight
« Reply #6 on: 16 April 2012, 18:57 »
Thanks everyone. Whats the SAI??
