Author Topic: Will my 20mm longer bolts be ok on 15mm spacers  (Read 862 times)
Offline rench
« on: 15 April 2012, 10:58 »
As above I've got some 20mm longer bolts will these be ok on my 15mm rear spacers? Or do I need to cut them down?
Offline shaft69
Re: Will my 20mm longer bolts be ok on 15mm spacers
« Reply #1 on: 15 April 2012, 11:55 »
I've got 40mm bolts to rear on 10mm spacer, standard bolts 28mmish. What length you got 60mm
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline rench
« Reply #2 on: 15 April 2012, 12:25 »
70mm full length and 45mm thread length
Offline Steve_PD
« Reply #3 on: 15 April 2012, 13:17 »
Should be fine. just fit them and rotate the wheel to make sure they don't clash on anything
Offline shaft69
« Reply #4 on: 15 April 2012, 14:04 »
That be ok only 5mm longer than mine and my spacer 5mm less so be cool.
184 Wallgate, Wigan
WN3 4AL
07966492823.
