Author Topic: Cruise control  (Read 1128 times)
Offline dickgam
Cruise control
« on: 15 April 2012, 00:38 »
Hi,
Any sugestions as to why the cruise control is not working? I switch it on, the light comes on in the clocks, press and hold set on the steering wheel and lift my foot of the pedal....... the car slows down!
This how I was told to set it, away at the moment but the handbook won on fleabay has turned up at home, just wondering if this was correct or is thgere a problem?
Cheers. :smiley:
Offline sveed1.8T
Re: Cruise control
« Reply #1 on: 15 April 2012, 01:02 »
Mine doesn't work either :sad:
Had a brief read a while back, n some people pointed to the clutch switch/sensor?? :huh:
If you find the cause, let me know, cus I really should sort mine out!!
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
Re: Cruise control
« Reply #2 on: 15 April 2012, 08:43 »
On mine all you do is click the switch on the wiper stalk then press the plus sign on the steering wheel and mines on.
Golf Gti
Offline sveed1.8T
Re: Cruise control
« Reply #3 on: 15 April 2012, 08:50 »
...thats if it is working properly :undecided:
Offline Jimble
Re: Cruise control
« Reply #4 on: 15 April 2012, 11:01 »
I don't think you have to hold the button down, just press and release? Could be wrong mind..
Offline bobbieboy69er
  • MK4 1.8T AUM
Re: Cruise control
« Reply #5 on: 15 April 2012, 11:39 »
Hi,
Cheers. :smiley:
Dont hold onto the button, thatll slow your down, just press it and it will enable.... thats as long as its actually working!
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline The Dave
Re: Cruise control
« Reply #6 on: 15 April 2012, 23:45 »
clutch switch is what was fubared on mine, took it out put it back in and it worked for 10 mins then died again... worth a try though :)
Offline dickgam
Re: Cruise control
« Reply #7 on: 16 April 2012, 00:24 »
Thanks,
When trying to use it I have puhed the set button, held the set button for a few seconds and it just loses speed so I think it is faulty! Where abouts are these switches located? On the peddles themselves?
Thanks for any help. :wink:
