Author Topic: engine mounts r they Knackered  (Read 1597 times)
Offline robson78
« on: 02 June 2005, 17:43 »
Whats the easiest way to tell if youre mounts are on the way out like how much movement is acceptable.?which mount is the most likley to go as well?Would this make noises wnen going over bumby ground
Car is mk3 16v with 77k .
Offline Andy Mc
Re: engine mounts r they Knackered
« Reply #1 on: 02 June 2005, 18:12 »
The front one is the most common one to go, and easy to swap.
Best way to check is leave the handbrake on, put it in gear and slowly raise the clutch whilst a mate stands and looks over the engine. When the clutch bites and the engine looks like it's about to leap out the bonnet then the mount will be shagged.
Drving along you will proberbly get some vibration when you pull away if there really knackered. Otherwise, you'll be able to feel the engine moving around when you pull away and also if you drive slowly but in a high gear.
'90 16v
Offline richandhazel
« Reply #2 on: 02 June 2005, 18:58 »
Excessive engine/gearbox movement can also get transmitted through to the gear stick.........accelerate and then deccelerate and see how much that gear stick moves. Oh hang on this is mk3, does that mean cable operated? In which case does the same theory apply :lipsrsealed:
Offline GolfGL
« Reply #3 on: 02 June 2005, 20:28 »
not sure if related but i was getting clunking over humps and turned out that the hub nut was loose so the hub was moving too much, for a few mins work might be worth checking
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline robson78
« Reply #4 on: 02 June 2005, 20:57 »
roger all of that . going to give that a try tomorrow.
Offline Mr Blue
« Reply #5 on: 02 June 2005, 22:47 »
Could also be your break pads shaking. the retainers could of dropped off or need bending back into shape. Go over a bump with the breaks pressed to see if the noise goes away.
Open your bonnet and shake the whole front end and listen for rattles. Listen to the top mounts to see if they click
(dont know much about mk3's)
