Author Topic: Buckfizzturbos Build Thread: VW Bora > Air Suspension > BBS RS  (Read 387654 times)
Offline JC
  • Back in the North.
Re: Brown MK3 Anni showcar on e level. **SHES STAYING** 08/01/13
« Reply #420 on: 10 January 2013, 20:25 »
I hope it's not bright orange or green like that player idiot
 :laugh:
Defo not nice classy colour
 :grin:
Offline Buckfizzturbo
« Reply #421 on: 10 January 2013, 22:42 »
 :laugh: :laugh: :laugh: :laugh:
LowCollective - East Anglias Premier German Car Event - 07/09/14 IP14 6AT
Www.lowcollective.com please search 'low collective cars' on Facebook
Offline joshstanvw
« Reply #422 on: 11 January 2013, 12:54 »
hi just read all the way through your thread and im now drooling lmao good luck and ill be watching for more updates
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
« Reply #423 on: 11 January 2013, 15:08 »
Cheers man appreciate you spending the time to read through. Now that the build is back on there will be alot more updates  :wink: :smiley:
« Reply #424 on: 18 January 2013, 16:30 »
hey guys,
ive still got a TT dash conversion with mk3 kufatec loom (£450), audi flat bottom steering wheel (£250) and some 17x8" RH zw1 splits for sale (£650). All in the for sale sections.
The reason for this post is that I'm after a R32 lump so if you have 1 and fancy the above as a swap let me know :)
Also after a little R32 conversion searching I've found out that you can:
-use a vr6 box for the conversion,
-it sits direct on mk3 mounts,
-dubpower do a manifold so you can use the vr exhaust system
-and I believe with a immobiliser defeat you can wire in the R32 ecu n loom into the vr loom n clocks.
Is what I've found out correct and if you have some more info I'd love to here from ya.
Thanks
Nathan
Offline tweed
« Reply #425 on: 18 January 2013, 17:10 »
Wanted to r32 mine and found out its easier than a 20vt swap. But I'm after the mk4 2.8 as you can buy the car for £1500.
It's as simple as you've said.
« Reply #426 on: 18 January 2013, 17:52 »
Glad to here it.
Yeah cost is the downside to it. I've got a vr lump ready to go in but 237bhp is alot better starting place than 174bhp. 63bhp will be hard to find in a vr unless I go turbo, supercharged or ITB and all will cost ££££s. exhaust, filter and map should see a R32 up a few bhp more
Offline Seanl
« Reply #427 on: 18 January 2013, 17:56 »
PM me your email address, as I've got some info on my computer from quite a few different forums regarding an R32 into a Corrado VR6. Its essentially the same as a Golf, and has part numbers of various things required you could sift through and decide what you need.  :smiley:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #428 on: 18 January 2013, 17:57 »
Makes sense really,  whats the R32 like in weight comparison?
Offline Seanl
« Reply #429 on: 18 January 2013, 18:00 »
Very similar weight to the VR6. No suspension or running gear changes required.
