Author Topic: golfvr6's vr6  (Read 3626 times)
golfvr6
golfvr6's vr6
« on: 30 September 2003, 08:48 »
Finally got my car back together yesterday with the help of Modulator, cheers geezer. New headgasket as the one in it was a sh!t pattern one that was starting to go on no1 cylinder. I will get some pics sent to Rich to upload soon. A little tip for everyone, if your headgasket is not flush on the head ie. it sticks out a bit then it is not a vw headgasket, be warned! something else to look out for when buying a car!
Offline adyh
Re:golfvr6's vr6
« Reply #1 on: 30 September 2003, 10:31 »
Aren't you concerned that your car has got through at least two headgaskets ?
golfvr6
Re:golfvr6's vr6
« Reply #2 on: 30 September 2003, 11:58 »
Not really mate, the other one was only slighty going, it was pressurising the coolant system. The old gasket was a poor quality pattern one, so i have used genuine parts. The point is do the job properly and it won't need doing again!
Offline modulater
Re:golfvr6's vr6
« Reply #3 on: 30 September 2003, 12:07 »
I think it was more the case of the original gasket went a year or so before you bought the car and the owner then fitted a pattern gasket rather than an original one.
 Also the early VR6 headgaskets were known to have problems and VW updated the 95 and on ones to prevent it. You car was a switch over year model as it has the square side repeaters so got a dodgy gasket from new.
From seeing it and helping do the job I am sure the job is now fixed and you wont have anymore problems with it.
Is the engine still smoking like a kipper from all the new coatings burning off?
« Last Edit: 30 September 2003, 12:10 by modulater »
golfvr6
Re:golfvr6's vr6
« Reply #4 on: 30 September 2003, 17:17 »
The wd40 smoke has gone now  ::)  should have got some pics  :o
Offline mk1
Re:golfvr6's vr6
« Reply #5 on: 30 September 2003, 20:35 »
Good to here that you got it done OK, see its not as bad a job as it first looks ;). Steve.
golfvr6
Re:golfvr6's vr6
« Reply #6 on: 30 September 2003, 20:37 »
Not as bad as it first looks? i think your takin the piss mate  ;)
Offline modulater
Re:golfvr6's vr6
« Reply #7 on: 05 October 2003, 23:49 »
Piece of piss, We do it in our sleep ;)
golfvr6
Re:golfvr6's vr6
« Reply #8 on: 06 October 2003, 14:52 »
Whats that? all the shouting and swearing  ::)
