Author Topic: FAULT CODES someone help!  (Read 1000 times)
Offline MrRodge
« on: 13 April 2012, 19:01 »
right basically the EPC light comes on and stalls when i come to a halt of driving or sometimes when just idling. Looses boost through the gears like 3k on wards, when putting my head under car can hear a tssssssss noise under the car small but hearable ?and fault codes i am getting are..
017705-turbo/supercharger connector valve pressure hose.
016706-ignition/distributor engine speed.
016622-turbo/supercharger boost
016395-"A" camshaft postition- timing.
Offline MrRodge
Re: FAULT CODES someone help!
« Reply #1 on: 13 April 2012, 19:59 »
anyone ? :(
Offline richw911
« Reply #2 on: 13 April 2012, 20:01 »
Boost leak?
Offline MrRodge
« Reply #3 on: 13 April 2012, 20:17 »
you saying all them codes will come up from a boost leak?
Offline richw911
« Reply #4 on: 13 April 2012, 20:29 »
17705 - Pressure drop between turbo and throttle valve (check DV) Possible boost leak
16706 Engine Speed Sensor G28 no signal    Faulty sensor or wiring
16622/P0238/000568 - Manifold Pressure/Boost Sensor (G31): Signal too High
Possible Symptoms
    * Malfunction Indicator Lamp (MIL) active
Possible Causes
    * Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31) faulty
    * Manifold Pressure/Boost Sensor (G31) faulty
Possible Solutions
    * Check Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31)
    * Check Manifold Pressure/Boost Sensor (G31)
16395  P0011 035 - 'A' Camshaft Position (Bank 1) Timing Over-Advanced or System Performance sporadic
Could well be linked to the above 16706 Engine Speed Sensor fault
 :smiley:
