Author Topic: water meth injection talk to me....  (Read 2778 times)
Offline Chris#101
Re: water meth injection talk to me....
« Reply #10 on: 14 April 2012, 22:34 »
I'm gonna be right anal about fitting mine lol, I want it all tucked away nicely :laugh:
What one are you going for wazzer?  :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Chris#101
« Reply #11 on: 14 April 2012, 22:36 »
I run devils own spot on no probs. Make sure use correct jet size for your car. Easy to fit done mine in hour and half. Put pump in spare wheel well and bottle against back seat run water feed in chassis with fuel line. Easy.
What kit do you have bud?
http://www.methanol-injection.co.uk/index.php?cPath=21&osCsid=9f91c0cacb1f402cf86f73f4ee3d9eab
how do you know which jet size to buy?  :lipsrsealed:
Using base kit 6-30psi correct nozzle does come with kit think mine D03 if i remember correctly, get 2 nozzles in kit. Would recommend highly use boost gauge and LED in between powwer cable to pump so exactly know what psi pump runs at, mine set to 12psi. I also fitted a switch so can turn wmi off, some time drive hard when car not at operating temp don't want wmi running till engine's hot. Want AEM digital controller soon but not cheap over £200, and have boost gauge built in. Depends how much want spend on wmi my fave if AEM it but one i wanted was £450 mines half that.
Cheers chap il probably go for the kit youve got then  :cool:, Ive already got a boost gauge installed if thats what you mean?
apart from a tank is everything needed in the kit youve got?
cheers in advance
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 14 April 2012, 22:46 »
Dave's kit which is a Devils own I think...
Offline shaft69
« Reply #13 on: 14 April 2012, 23:45 »
There brill want nick r-tech set mine car up correctly with custom spec2 map.  Got loads stuff needs fitting to mine yet
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Kyle!
« Reply #14 on: 15 April 2012, 00:09 »
This lol
http://uk-mkivs.net/forums/p/473515/3251643.aspx#3251643
^^ Clicky For Build Thread (Updated 17/08/12) ^^
Offline Chris.
« Reply #15 on: 22 April 2012, 13:55 »
Didnt Nick's devils own kit fail?
Click For Build Thread
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #16 on: 22 April 2012, 14:15 »
I think he had problems with the controller. AFAIK they have revised it now
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #17 on: 22 April 2012, 14:21 »
Could you do this to a diesel?
Am I right in thinking that the water/meth mix gets sprayed into the inlet manifold?
Offline wretch20vt
« Reply #18 on: 22 April 2012, 15:43 »
yes
