Author Topic: Errors MK5 gti after battery removal  (Read 1644 times)
steelandy
« on: 12 April 2012, 13:23 »
Hi,
I am having some problems after removing the battery on my mk5 gti. did this to reset error codes from ecu as recommended by the garage i went to for my exhaust.
However after restarting the car i have error lights on the steering, esp and tyre sensors.
Any ideas?
thanks.
edit - went for drive all reset and all is well.
« Last Edit: 12 April 2012, 13:37 by steelandy »
Offline Dannyavw
Re: Errors MK5 gti after battery removal
« Reply #1 on: 19 April 2012, 22:37 »
the tyre pressure light will turn off if you press and hold the button until you hear a beep and as for the ESP and steering light they are on due to the steering angle sensor looseing it's live feed, drive in a straight line and the lights should go out other than that you may have to carry out basic settings of the angle sensor
