Poll
Timing
Dont know
0 (0%)
Guessing
0 (0%)
Total Members Voted: 0
Voting closed: 13 April 2012, 23:40
Author Topic: Timing settings mk3 gti 2.0 8v  (Read 2094 times)
Offline mikey_magic
« on: 11 April 2012, 23:40 »
Hi guys, does anyone know the timing settings on a agg engine, my so called machanic has got a timing light and was unable to do timing after having a new dizzy fitted as car wouldn't rev over 5000rpm it really can't be that far out as one day it's fine the other it won't rev over the 5000rpm, any helpers......
Offline leegt5
Re: Timing settings mk3 gti 2.0 8v
« Reply #1 on: 12 April 2012, 00:42 »
This should help with setting the timing correct if the dizzy has been removed and your getting 5k rev limit !!
http://www.golfgtiforum.co.uk/index.php?topic=189242.msg1768205#msg1768205
Offline mikey_magic
« Reply #2 on: 12 April 2012, 09:19 »
Thanks for that, however that all seems to be fine and lined up ok, can it be timed up with a timing light sorry to sound a bit thick but engine side of things isnt my best,
Offline javalin
« Reply #3 on: 12 April 2012, 11:21 »
AGG should be statically timed - i.e. when the engine is off.  Dynamic timing (with light) not required.
http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/t-belt/index.htm
see the later pictures on the above link.
Would get a better mechanic personally.  Hope he is not charging you when you give him the information.....
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
