Author Topic: summer coolant  (Read 1533 times)
Offline devilscaff
  • allways up for alaugh
summer coolant
« on: 11 April 2012, 20:16 »
Is it best to fill engine with neat coolant or is it worth 50/50 mix with water?
Offline The Mighty Elvi
  • I'm better than you today.
Re: summer coolant
« Reply #1 on: 11 April 2012, 21:00 »
Do exactly what is says on the tin.
Offline Anthony
Re: summer coolant
« Reply #2 on: 11 April 2012, 21:07 »
as above, normal mix is 50/50 you wont gain anything from using it neat. Antifreeze is a thick sticky product so would reduce flow as well if used neat
2003 GT Tdi 150
Re: summer coolant
« Reply #3 on: 11 April 2012, 21:14 »
The whole point of coolant is that it raises the boiling point and lowers the freezing point.
You need to add water to make it more fluid.
Offline devilscaff
Re: summer coolant
« Reply #4 on: 11 April 2012, 21:18 »
Il set to it at the weekend, is it worth using G12 or will any do?
Offline Seanl
Re: summer coolant
« Reply #5 on: 11 April 2012, 21:43 »
G12++ from the dealer as recommended. Its no more expensive than the sh!te you'd get at halfrauds either so no need not to.  :wink:
Offline rob.043
Re: summer coolant
« Reply #6 on: 12 April 2012, 09:26 »
The water is also there as it has a better specific heat capacity than coolant, i.e. it can carry more heat. Meaning it moves more heat away from the hot bits to the the radiator. So you may get overheating issues with coolant only!
Offline Sam
  • Sam I am
Re: summer coolant
« Reply #7 on: 12 April 2012, 16:54 »
Yadadadadadadadadadaayayaya 33%
