Author Topic: Head gasket failed?????  (Read 1407 times)
Offline markymarkg
« on: 10 April 2012, 20:38 »
The headgasket has blown on me today.....i think!?!
Getting lots of back pressure and the coolent pipes going hard, also when i start the car up, it struggles to run and lots of steam coming out then it clears.  No water in oil yet.
Would anybody agree thats the problem??
Would you change the head bolts when changing the head gasket???
Cheers.
« Last Edit: 10 April 2012, 20:43 by markymarkg »
Offline andy-gti84
  • lowanslow
Re: Head gasket failed.
« Reply #1 on: 10 April 2012, 20:45 »
sound like it mate as same happend to me when i had a astra sri. u can pick up a full head kit an most do come with new bolts so is best to change them. might as well do cam belt etc as well if ya stripping it all down. is a sh!tter when it happen but if ya happy doing it your self then u will save ££££.
good luck  :smiley:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 10 April 2012, 20:47 »
Sounds like it could be leaking between the cylinders and coolant galleries, it wont necessarily mix oil with water of vise versa depending on where it fails.
Compression test is the next step,  They don't cost much to buy if you don't have one, and a very handy tool to have.
Yes to the bolts, all the MK3 engines use stretch bolts.
And yes to a new cam belt as mentioned above, I insist on replacing when they have been removed.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline shelaghmk3gti
Re: Head gasket failed?????
« Reply #3 on: 10 April 2012, 21:34 »
mine went on me last month  :sad:  was a very expensive job too ( i couldnt do it)
i did tho ask a zillion questions on here whie i shopped around for quotes ..and all of those things that you mention dont actually mean head is gone..
mine overheated on the motorway rapidly, wouldnt hold water.. had white smoke the next day and very little power.. tho it did drive ( i drove it home not knowing what it was  :lipsrsealed:) saved me the towing fee anyway :tongue:
and of course the mayonaise type mess under the oil fill cap.
i really hope its not the head for you, but yeah i had all sorts of hassle with the garage that did mine.. so if you can  get someone highly recomended and sort out skimming etc yourself youll save afair few quid!
mine cost £480 ( he tried t charge me another £60 for the belt too!! but after the rad pipe blew off 2 days after having her back he had her back in to drain refill etc and forgot about the 60 quid  :smug:)
fingers crossed for you.
« Reply #4 on: 10 April 2012, 22:03 »
Sounds like the head gasket but get someone to confirm if they can with a block tester.
Offline markymarkg
« Reply #5 on: 26 April 2012, 22:21 »
Job done!.
It was just the gasket that had failed. Sourced all the parts from a mate who works at an auto parts store.
I did all the work myself including pressure testing the head at work and getting a it skimmed.
Replaced the head gasket, head bolts, rocker gasket, inlet manifold gasket, all exhaust manifold gaskets, timing belt and tensioner, cam and crank shaft seal, both auxillary belts and water pump.  £135 total..and that was with alot of discount!!!!
Got a quote from a local garage as well and they wanted near £700 quid!  yikes!!!!
« Reply #6 on: 26 April 2012, 22:34 »
wow.. well done you!!! x
