Author Topic: no heater  (Read 1851 times)
Offline danmusic24
no heater
« on: 10 April 2012, 09:47 »
had a hose go on my 16v last night,i have replaced hose and topped back up with coolant but have no heaters? is this a airlock somewhere or some other reason? cheers :smiley:
Offline kahunajb
Re: no heater
« Reply #1 on: 10 April 2012, 10:39 »
Would have thought an air lock is a good bet. Did you run the engine with the expansion tank cap off for a few minutes while topping up and massaging the pipes to expel all air?
Mk1 Leon Cupra TDI - Keeping
Mk5 Golf GTI - Revo Stage 1 - FOR SALE £5,250
Mk3 GTI 16v Anniversary - OEM+ - Gone :(
Mk4 GTI 2.0 - Slow - Good Riddance
Offline danmusic24
Re: no heater
« Reply #2 on: 10 April 2012, 10:43 »
yeah,gave them a good squeeze.its a bit better just luke warm?
Offline VR6_Wherry
Re: no heater
« Reply #3 on: 10 April 2012, 11:47 »
Do that again but with the heaters on full wack again.
Offline kahunajb
Re: no heater
« Reply #4 on: 10 April 2012, 12:38 »
Id start with the engine cold and the cap off and when the coolant starts evaporating put the cap back on topping up as required.
Offline danmusic24
Re: no heater
« Reply #5 on: 10 April 2012, 13:32 »
that worked! Cheers
Offline VR6_Wherry
Re: no heater
« Reply #6 on: 10 April 2012, 13:43 »
that worked! Cheers
 :wink:
Done my VR6 too many times now :sad: :grin:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: no heater
« Reply #7 on: 11 April 2012, 17:06 »
Make sure you blead it with the heater on full, keep gently squeezing the pipes, with the coolant cap off, run it,  cycle between idle and 2500 rpm, top up as required, ensure the heaters are on hot and running, when it blows hot, and no more air comes out, its done.
Another handy tip is to raise the front of the car as high as possible on stands or a ramp, unscrew the coolant bottle, and move it forwards as far as possible, helps get the air out.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
