Author Topic: Panasonic Lumix DMC-G3 or Canon EOS 1100D?(ITS HERE :)  (Read 12741 times)
Offline T_J_G
Re: Panasonic Lumix DMC-G3 or Canon EOS 1100D?(ITS HERE :)
« Reply #20 on: 12 April 2012, 17:56 »
Canon 50mm f1.8 lens. Which will teach you loads about photography. It's a fixed focal length (prime) that has no zoom and therefore is higher quality glass. You can zoom in/out with stepping forward or back.
It also has a aperture of f1.8 which allows faster shutter speeds in low light situations.
It only retails around £80 and is a fantastic investment!
Also a tripod isn't always necessary if you're shooting at a high shutter speed.
Offline LowlifeDubber
« Reply #21 on: 12 April 2012, 18:05 »
Ah right,not sure how to change the shutter speed yet,i thought i was being all technical getting my tripod out till i ripped the skin on my fingers opening the bloody thing! :grin:
Ebaying now for the lens.
Any other must have i need?Battery grip jobby?Them polarizing thingys for the end?
« Reply #22 on: 12 April 2012, 18:06 »
Ah Flickr,much better thanks  :grin:
Offline T_J_G
« Reply #23 on: 12 April 2012, 18:37 »
Remember you don't NEED anything. Learn the camera, and how to use it and go from there. When you hit a limitation then invest. Battery grip shouldn't really be top of your list until you find out you're running out of power to quickly. Even then you can look into having a spare battery.
Lens here: http://www.warehouseexpress.com/buy-canon-ef-50mm-f1-8-ii-lens/p12814
Ebay tends to sell a lot of grey imports so personally I'd always buy from Jessops/WarehouseExpress and so on.
Offline DubFan
« Reply #24 on: 12 April 2012, 18:47 »
I wouldn't bother with using a tripod if it's a bright day. You only really need a tripod if you are going to use slow shutter speeds.
As for the next purchases,
1) a case or bag
2) spare battery
3) spare memory card
4) zoom lens 55-200 or similar
5) 50mm f1.8 lens (also known as a 50mm prime or "nifty-fifty")
6) polarising filter - used for a) improving the blue colour in the sky on bright days or b) reducing reflections
You could get these in any order really, but you need a case for sure. The 50mm lens will teach you a lot about composing your shots and depth of field, and it's much better quality glass. (Check out my thread comparing the kit lens to the 50mm, it's not for a Canon camera but the it gives you an idea of the quality difference)
I wouldn't bother with a battery grip until you're more experienced and confident otherwise you're just adding weight pointlessly.
I would spend plenty of time learning about composition and the rule of thirds (see here), focus points, ISO, shutter speed, aperture and depth of field (see here).
Enjoy
« Last Edit: 12 April 2012, 19:15 by DubFan »
« Reply #25 on: 12 April 2012, 18:58 »
Outstanding info thankyou. :smiley:
Offline T_J_G
« Reply #27 on: 12 April 2012, 20:13 »
Just downloaded it for the kindle thanks mate :)
Offline Luke1981
« Reply #28 on: 12 April 2012, 21:41 »
I just purchased this lens from this company. Well worth it  :wink:
http://www.ebay.co.uk/itm/NEW-CANON-EF-S-55-250mm-f-4-5-6-ZOOM-LENS-55-250-mm-/110723532114
It costs £270 in Curry's
Luke
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Diamond Hell
  • Opinions я Us
« Reply #29 on: 13 April 2012, 11:23 »
This, in spades. The more photos you take, the more you'll understand what you want.  Do not just buy on spec.  Use the hell out of the camera and you'll get masses out of it.
