Author Topic: How important is the outer rubber bit on the spring cup?  (Read 710 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
As above, mine is completely shot and has fallen to bits... :sad:
Offline old_n07
Re: How important is the outer rubber bit on the spring cup?
« Reply #1 on: 09 April 2012, 12:19 »
Do you mean the rubber ring on the metal limit stop that comes up through the turret Waz?
If it is that I think it is just to stop metal to metal contact at extreme suspension travel so assides from that I can't see it being a big problem.
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 09 April 2012, 16:19 »
that's the one mate. I thought it was something like that cheers. I'll order some more caps anyway, might order the Polo versions as they're the same depth as the Supersport versions I've got with my poly top mounts. Might even chop over to the full Polo setup
Where you been hiding?
Offline old_n07
« Reply #3 on: 09 April 2012, 18:39 »
I've been lurking in the shadows mate  :evil:
