Author Topic: DIY for replacing the gearshift relay shaft  (Read 41635 times)
Offline Dolly
« on: 07 April 2012, 21:58 »
Well my 8v Gti gear change was like stirring porridge, massive amount of forward and backward play. found the problem was a worn bush on the relay shaft so £15 and 15 minutes later its fixed and along with a new clutch cable has transformed the way the old girl drives..
Only got pics with the new but its the same...
Undo the Nut on the top 13mm
Lift off the gear linkage
Get underneath and flick the clip off with a small flat blade screw driver
Lift out and compare with the new one..
Get your bits and refit, be sure to locate the bush into the linkage below the top nut and to left as you look directly down
Enjoy a much improved gearshift  :grin:
and a random pic to show how it fits together on the top
Offline JC
  • Back in the North.
Re: DIY for replacing the gearshift relay shaft
« Reply #1 on: 07 April 2012, 22:03 »
shall i get the bits and do a drive by to yours dolly  :wink:
Offline Dolly
« Reply #2 on: 07 April 2012, 22:08 »
Lol, its a very easy job, Dolly Spanner Rating on 1-10 is 2 as you have to get under the car, wouldnt advise doing it on the widow maker that is supplied in the boot though  :tongue:
Offline twotwofour
« Reply #3 on: 04 August 2012, 10:39 »
Just finished replacing mine, on my mk3, this guide was very helpful, an easy job that was 15 minutes well spent.
Nice slick gear change again!
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline vii-cks
« Reply #4 on: 12 September 2012, 15:15 »
Brilliant guide wish I'd have had this when tackling it on my mk2.
Vee Dub Machine do a nice little kit I have also found out, I got all my parts from GSF though.
Offline beechymonza
  • mad beech
« Reply #5 on: 08 January 2013, 15:22 »
Does this stop it from going straight across into reverse, Or is that the ball on the bottom of the gearstick
No guts No glory,
Offline Gambit
« Reply #6 on: 07 March 2013, 10:24 »
thats the ball/spring/cup at the bottom of the gearstick
Offline search
« Reply #7 on: 21 June 2013, 17:31 »
This could help me out a lot as its getting harder n harder to get back in to second gear, is this in the same location in all mk2s? as i have a 1.3 and pretty sure my clutch cable setup is different from this. cheers.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
