Author Topic: Switched live  (Read 1559 times)
Offline gizmomk3
  • on my way
Switched live
« on: 07 April 2012, 10:36 »
Want to put a flashing led in the car as a dummy alarm but can not find switched live off the key
If any one can help
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Switched live
« Reply #1 on: 07 April 2012, 10:43 »
As its just an LED,  if you want an ignition live, and reasonably easy access,  you can tap into the back of the stereo, i wouldnt normally say this but as its an LED it wont do any harm at all.
Otherwise, you can probe the chunky wires in the back of the fuse box, i cant remember which one but one or more of those is switched live, easy to get too, just drop the box down off the clips.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline gizmomk3
  • on my way
Re: Switched live
« Reply #2 on: 07 April 2012, 11:40 »
Any one know where in the fuse box thanks
Offline Luke1981
Re: Switched live
« Reply #3 on: 07 April 2012, 13:43 »
Use the live from the stereo as stated above, its easier than messing about with the fuse box.
Use a wire splicer though  :smiley:
http://www.ebay.co.uk/itm/Blue-Snap-Cable-Connector-Scotch-lock-Wire-connector-Splicer-x10-/350537830879
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline pootas
Re: Switched live
« Reply #4 on: 07 April 2012, 14:44 »
I did exactly this on a mates mk3...Spliced from back of stereo and wire pulled through dash...As long as it's all properly insulated it'll be fine
<a href="http://giffgaff.com/orders/affiliate/pootas" target="_blank"><img src="http://giffgaff.com/banner/07_468x60.png" width="468" height="60" alt="Get a free giffgaff Sim" /></a>
Offline gizmomk3
  • on my way
Re: Switched live
« Reply #5 on: 07 April 2012, 15:31 »
Can not find the switched live on radio had it out and all a got is a live with the key in and out
Offline Rmachines
Re: Switched live
« Reply #6 on: 08 April 2012, 17:58 »
Orange is live and red is switched i think,   its the opposite to most makes.  :grin:
Offline vwscottie
Re: Switched live
« Reply #7 on: 10 April 2012, 17:52 »
Behind the ignition switch is a wire that goes live when the key is removed but i can`t remember what colour it is. I`d say this is what you will need for a dummy alarm LED not one that`s live when the key is in the barrel
Offline kempie
  • where would we be without duct tape?
Re: Switched live
« Reply #8 on: 10 April 2012, 19:23 »
chuck it on the end of a 9v battery? obviously dont have the battery on show
Offline gizmomk3
  • on my way
Re: Switched live
« Reply #9 on: 10 April 2012, 20:00 »
Sorted now getting a proper alarm with central locking starting to get a bit miffed at putting the lie in the door al the time to oped dam car lol
