Author Topic: Dropped off at r-tech! ..Results!  (Read 12241 times)
Offline cullygti
Re: Ringing to book map tomorrow!
« Reply #20 on: 01 May 2012, 09:39 »
 :cool: i bet your like a big kid now and you will probably get home much quicker than you usually would  :laugh:
Offline golfyste
  • Project track car
Re: Dropped off at r-tech!
« Reply #21 on: 01 May 2012, 10:00 »
Yeah around abouts not a set pick up date gotta see how it goes   :cool:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #22 on: 01 May 2012, 18:42 »
Had an afternoon to work on the car and getting it to play ball my way... mainly just setting up the boost to run fully open loop under full load to get the best and most linear boost profile.   With 21psi peak I am seeing 288lbft :wink:  not worked on the peak power yet just midrange on stock injectors and still seeing 244bhp.   So far looking good.
Tomorrow Jim is going to get the BAM injectors fitted and rip the engine apart to try to find fault..lol then we can move on to thr bulk of the tuning and logging and make power  :grin:
Are you running yellow spring in forge actuator? it feels and acts like one
Nick
 01455 617233
Offline golfyste
  • Project track car
« Reply #23 on: 01 May 2012, 18:49 »
That sounds awesome mate !  :smiley: can't believe you have got that in one afternoon  :laugh:, did try ringin you but think you had already closed up?
Ok nick that sounds great have you put in the new plugs yet?
And yeah it's a yellow spring about 2 months old  :smiley:
Will give you guys a ring tommorrow afternoon, when do you close up?
Cheers pal  :smiley:
Offline golfyste
  • Project track car
« Reply #24 on: 01 May 2012, 18:53 »
Another question nick, did you you do any dyno runs to start with? Didn't know if you would with the different turbo but was wondering what sort of figures it was puttin out  :smiley:
Cheers mate  :smiley:
Offline RTechUK
« Reply #25 on: 01 May 2012, 19:11 »
stock 165bhp 180lbft with ecu cutting n75 to 0% and cutting throttle plate angle.
Today was only to get control of the boost via writing a base line open loop n75 map, so basically making the ecu work like an electronic boost controller, so 70% n75 dc is my upper limit to produce 21psi peak 288lbft and taper to around 12psi  at the top end still with 70% dc to make 244bhp.    Tomorrow its Jims turn to work on the car to make sure and get the car mechanically sound, injectors, plugs, smoke test, pressure test, cam/crank timing test.
then wind the car up for power, the only flow limit I can see is the exhaust system.
 01455 617233
Offline golfyste
  • Project track car
« Reply #26 on: 01 May 2012, 19:19 »
Ok mate, they are the sort of figures I were expecting, has it been mapped before do you know?
That's sounds sweet mate will give you a bell tommorow see how your gettin on or just write a little on here.
Which part of te exhaust do you think as I did my best at porting the manifold.
Offline turbokid23
« Reply #27 on: 01 May 2012, 19:27 »
how long do you have the car for nick???
Offline golfyste
  • Project track car
« Reply #28 on: 01 May 2012, 20:27 »
About a week for me as its a k04-001  :smiley:
Offline turbokid23
« Reply #29 on: 01 May 2012, 20:31 »
mine would be the same then as i have a ko4-22 to go on mine :rolleyes:
