Author Topic: Dipstick / funnel broken off  (Read 1480 times)
Offline CitizenKane
« on: 06 April 2012, 19:54 »
Hi all,
First post, so apologies if this is in the wrong section or anything (but I do drive a mk4 so I thought it would be a good bet...)
Basically my oil light came on so went to the garage to check it. Pulled out the dipstick, wiped it off, tried to put it back in and it wouldn't fit, it only went about half way down, as if there was something blocking it going fully in. I spent about 10 minutes trying to wriggle it around to see if I could get it in but to no avail. Eventually, probably due to the incessant wriggling, the top of the 'funnel' part that the dipstick goes into (if that's the right word for it), snapped off. So there is now no dipstick. The oil tube is now exposed but there is no oil leaking.
My question is:
1. Has anyone experienced this before and if so was it easy/cheap enough to get sorted?
2. Should I be ok driving around for a few days by just covering the exposed hold with some duct tape or something to make sure that no debris gets in?
Cheers in advance.
jockgti
Re: Dipstick / funnel broken off
« Reply #1 on: 06 April 2012, 20:01 »
can get a new tube for about a fiver and yes its common as it heats up and cools down and gets brittle,just be careful none falls down tube while pulling it off
http://www.ebay.co.uk/itm/Dipstick-Guide-VW-Golf-Mk4-1-6-1-8-1-8T-1-8GTI-Turbo-GTI-Dip-Stick-Tube-NEW-/360441916844?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53ec032dac#ht_1981wt_1037
Offline Chris#101
« Reply #2 on: 06 April 2012, 20:03 »
Common as muck on the golf, new dip stock guide is 4 pound from tge dealers :)
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Jonnybbad
« Reply #3 on: 06 April 2012, 20:08 »
£2.75 from GSF typical crap vw design
