Author Topic: Mananged to bend all 16 valves today on a focus.  (Read 1633 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
I purchased a 1.4L Ford focus a few days ago for my sister,  put an MOT on it, needed a new bush, which i did first, then serviced it, polished, with a full valet, then i went to do the cambelt.... (did it at work in the workshop where i had all the correct kit)
Timed it all up with the locking pins (has free floating crank pulley) fitted a gates cambelt kit, then refitted the bottom bolt and pulley aux belt pulley with the original bolt (only supposed to be used once), fired her up, lovely all good!  So i remove the bottom pulley again, to fit the covers, this time i use the new bolt which came with the kit,  started it again... spluttered, died, then i cranked it... loss of compression... surly not, couldn't have....  checked it over, timing was spot on as per the marks i made, but when fitting the locking kit blow me, the timing had slipped right out and done every bloody valve!
Turns out the gates kit came with a new bolt which was far to long, i assumed (after confirming it was the correct kit with the supplier and on the sticker on the box) the bolt was longer as the result of a known issue (as the tensioner was also changed due to past issues)  it didn't compress the free floating bottom pulley the thread hit the end of the hole causing it to slip .....destroying the engine
Very very teasey!!!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline AudiA8Quattro
Re: Mananged to bend all 16 valves today on a focus.
« Reply #1 on: 05 April 2012, 23:20 »
Ouch!!
Offline Jay
  • balding fat cvnt
« Reply #2 on: 05 April 2012, 23:29 »
Are the manufacturer or supplier going to rectify this eeing as it was a known issue?
VW BUSH
« Reply #3 on: 05 April 2012, 23:30 »
ouch
Offline danny_p
« Reply #4 on: 05 April 2012, 23:39 »
automotive parts warranty / come back against manufacture f**kup mistake = myth
never had an issue with gates as of yet,  last one i had was with BGA who just ignored everything  denied all knowledge of anything and ere general twits
all the VW's have gone bar 1.
Offline Rmachines
« Reply #5 on: 07 April 2012, 09:02 »
I have always been a big fan of gates, but not so much now, i will see what they say when i kick off about it.
Offline dan2252
« Reply #6 on: 07 April 2012, 09:09 »
own a few fords now. and done the cambelts on a few. the cams are floating too. and your meant to loosen them off to take the slack out of the belt did you? as the first one i did i ever did and timming jumped 2 teeth luckly didnt bend and valves just missed and poped haha,
MK4 golf 1.8 turbo agu :)
Offline Rmachines
« Reply #7 on: 07 April 2012, 13:34 »
Yea it was all done properly, I'm a diagnostic tech for honda, and i did it at work with the proper locking kit,  i have done many floating cams before in the past, and the fact this was running fine with the old bolt, and slipped in the crank with the new longer bolt says it all, the longer bolt leaves about 1mm gap, so it was basically left loose, im awaiting a response from gates now.
Offline Mr GTD
« Reply #8 on: 07 April 2012, 15:36 »
Nasty!!
Offline gti gaz
« Reply #9 on: 08 April 2012, 20:06 »
Ouchhhh
 Any one in cornwall lets sort more meets!!!!
