Author Topic: de cat or sports cat good benifits?  (Read 1352 times)
Offline rench
« on: 04 April 2012, 23:02 »
whats best option de cat or sports cat, do you notice the gains and does it become much louder through exhaust?
Offline Steve_PD
Re: de cat or sports cat good benifits?
« Reply #1 on: 04 April 2012, 23:31 »
De-cat will be illegal on the roads :tongue:
Sports cat won't.
Easy answer..
« Last Edit: 05 April 2012, 00:05 by Steve_PD »
Offline Scott D
« Reply #2 on: 04 April 2012, 23:37 »
sports cat is less hassle come MOT time, turbo will spool up quicker with both and should get a good few extra HP even more so after a remap.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
« Reply #3 on: 05 April 2012, 00:02 »
Sports cat won't.
Easy answer..
Have you not got that the wrong way round :huh:
« Last Edit: 05 April 2012, 00:06 by Steve_PD »
Offline Steve_PD
« Reply #4 on: 05 April 2012, 00:06 »
No, get some glasses old man :lipsrsealed: :grin:
Offline stfc_gti
« Reply #5 on: 05 April 2012, 08:54 »
Sports cat won't.
Easy answer..
no, hes right, decat would fail an MOT too (unless your mates a tester)
2002 1.8T GTI AUM, Standard (not for much longer)
Offline shaft69
« Reply #6 on: 05 April 2012, 09:26 »
Personally I'd go sport cat route I've got 3"APR d/p with so with sport cat. Decat cheapest way , know where you ate when cat fitted to car no messing on mot later date. That doesn't bother me as do my own mot so not going to fail.  :grin:
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline navmk4gti
« Reply #7 on: 05 April 2012, 09:48 »
if you have a freind who does mot's then just get decat and downpipe.. i felt difference striaight away picks up a lot better.. never had it on dyno after so dont know gains i got .. i got the toyosport one from the bay for £55  :smiley:
