Author Topic: Replacing the steering wheel airbag  (Read 676 times)
Offline Gozza
« on: 04 April 2012, 20:55 »
Hi all,
If the drivers airbag had deployed, could I just buy another steering wheel airbag and replace or do I need any other bits ?
Thanks
Offline richw911
Re: Replacing the steering wheel airbag
« Reply #1 on: 04 April 2012, 21:01 »
The sensors and module must also be replaced,the control module records a permanent code when there is a deployment and it cannot be reset without a specialist afaik
Possibly issues with the seatbelts?  :undecided:
Offline Gozza
« Reply #2 on: 04 April 2012, 21:13 »
Ah ballbags, only reason I asked is I bought a damaged TDI where the airbag has gone off. Got a replacement on Ebay for £6.50 haha.
If I just replace the airbag without the other bits will it go off again or just report an airbag fault each time the ignition is on ?
Thanks
