Author Topic: Its all gone a bit Pete Tong !!!!!  (Read 2518 times)
Offline chicken boy
« on: 31 May 2005, 15:45 »
Need some big help folks, got a 1991 8v digi (factory spec) which was running sweet when i bought it. Had a K&N induction kit fitted bit of a cowboy job but no probs, car sounded sweet as well, occasional bit of backfire but nothing major. Just had a powerflow full exhaust fitted and everything was fine for about a week. Now the damn thing hardly starts, here comes the pain :
Just ready to head of to the Scottish vw show at Biggar and it wouldn't start, it was raining heavy and the battery light on the dash was coming on when trying to tick it over. starter sounds fine and battery is fine but wouldn't start. I let the car dry and manged to start it with a jump start everything seemed ok for a couple of days a few starting probs but didn't seem too bad.
Tried to start it today but it was a nightmare, the engine was knocking away and it just sounded horrible even when it was running
didn't get more than 100 yards before it cut out again. Checked the HK leads and there was some oily liquid at the orange cap end on all four leads the spark ends were ok. Also should the bottom pipe at the air box be opened or closed, the one beneath the air filter?
I know its bad news but what is wrong and what can i do ?
fingers crossed and cheers
 :cry: :cry:
Offline monkeyalan
Re: Its all gone a bit Pete Tong !!!!!
« Reply #1 on: 31 May 2005, 15:57 »
have you checked the rotor arm in the dizzy and the dizzy cap itself?
Offline chicken boy
« Reply #2 on: 31 May 2005, 16:00 »
bit of a newbie so not too sure what the dizzy is ??!! except my poor head
Offline Rain
  • forum irregular
« Reply #3 on: 31 May 2005, 16:08 »
if the cars not running that flap thing in the should be closed might be the mfa up the spout but id test your battery and alternator first to be sure there ok.
Offline BobbyT
« Reply #4 on: 31 May 2005, 16:09 »
have you checked the crank case breather??
Offline Rain
  • forum irregular
« Reply #5 on: 31 May 2005, 16:10 »
distributer cap round thing with the 4 ht leads plugged into remove the top and look at the rotor arm inside.
Offline chicken boy
« Reply #6 on: 01 June 2005, 13:33 »
 brilliant folks
had a look and the arm was well gone, gonna replace it this afternoon so fingers crossed.
Is this just old age or is there anything else i should be concerned with ??
ps hopefully some pics of the car on the way
« Last Edit: 01 June 2005, 13:51 by chicken boy »
Offline Rain
  • forum irregular
« Reply #7 on: 01 June 2005, 18:24 »
old age wouldnt worry too much but if its that far gone id check the leads and replace the cap aswell cap and arm cost you about a fiver in total there not expensive.
Offline chicken boy
« Reply #8 on: 02 June 2005, 14:07 »
Yeah just replaced the arm and cap and ma baby is starting at least.
Just need to do the sparks and it should be all good. Sounds like it is only firing on 3 cylinders
cheers
Offline monkeyalan
« Reply #9 on: 02 June 2005, 14:15 »
get new HT leads like Rain said,might solve the problem and it can't do any harm. I once had a rotor arm explode on my jetta while i was doing 80 in the outside lane, talk about fill my pants! :shocked:
« Last Edit: 02 June 2005, 14:17 by monkeyalan »
