Author Topic: MK2 audi TT wheel, how do they do it???  (Read 3566 times)
Offline kiwgti
« on: 31 May 2005, 13:31 »
At the min i have a 1991 mk2 golf gti 8v, and i want to put a set of audi tt wheel on as i think this will look to part on the mk2, at the min the brakes are 239mm, so does any one out there know how to do the conversion,
if so could u plase replay to this thanks for reading everone,
aaron :smiley:
Offline Mr Blue
Re: MK2 audi TT wheel, how do they do it???
« Reply #1 on: 31 May 2005, 14:59 »
so your after Audi TT competition wheels? (the 5 spoked polished bad boys)
Cound change the hubs for mk3 gti ones i think and the TT's should bolts right on.\
Easiest option would be to buy hub adaptors but this might cause the wheels to stick out more
Offline jv
  • Administrator
« Reply #2 on: 01 June 2005, 13:19 »
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Mr Blue
« Reply #3 on: 01 June 2005, 14:29 »
sweet :cool:
 :tongue:
« Last Edit: 01 June 2005, 14:49 by Blue Mk2 »
Offline carl
« Reply #4 on: 01 June 2005, 16:48 »
you will have to roll the arches and cut the trim to fit them and swap hubs for mk3 ones or fit adapters pain in the arse, my brothering law got my old mk2 with 16in alloys and i had to cut the front lips off the wings for them to fit ,ive got audi tt comp wheels on my mk3 lowered 70mm and i just get away with no mods the mk3 have much more room under arches ,but if you fit these wheels i agree they look wicked on mk2s
Offline Agreeable Slick
  • Unit
« Reply #5 on: 01 June 2005, 17:22 »
If you are going to cut the trims then make sure you get them welded back up again, especially at the back as there is a seam running along the arch. Do not just whack some filler in there and paint over it.
As mentioned the best option is to change the hubs to mk3 ones, and they will bolt straight on. If you want to put an adapter on then it will push the wheel out by at least 15mm, if not 20. So add that to the ET of the wheel and then get measuring.
Happy trails.  :cool:
Offline Dizzie
  • Make friends with your fast
« Reply #6 on: 01 June 2005, 23:35 »
btw, from what I've heard putting mk3 hubs on a mk2 is a sl*t of a job.
if you welcome a challenge :D
