Author Topic: whats the diffrence between a 115 and a 130 bhp clutch  (Read 3930 times)
Offline darren1.8t
  • I HATE FRENCH CARS
as above is there any diffrence cheers
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: whats the diffrence between a 115 and a 130 bhp clutch
« Reply #1 on: 03 April 2012, 19:28 »
Couldn't tell you categorically. I know that the 130 & the 150s have the same clutch/flywheel set up and a 115 clutch doesn't fit in a 150. I think the flywheel diameter is different... :undecided:
Offline darren1.8t
« Reply #2 on: 03 April 2012, 19:40 »
ok mate if a 130 fits then i can get it cheap lol
Offline scarr89
« Reply #3 on: 03 April 2012, 21:33 »
I don't think it will... :rolleyes:
As I said I know the 130 and 150's are the same clutch and a 115 does not fit a 150...
Offline Steve_PD
« Reply #4 on: 04 April 2012, 23:45 »
same size clutch, IIRC its 240mm. All 6 speeds have the same size clutch which are more expensive than the 5 speeds
Offline darren1.8t
« Reply #5 on: 05 April 2012, 06:34 »
thanks steve is it all the same flywheel/plate etc  so i could fit a 130 flywheel and clutch ??  :cool:
Offline Steve_PD
« Reply #6 on: 05 April 2012, 16:51 »
Should be the same size. IIRC 6 speed diesels use the same clutch and flywheel.
ebay link to sachs tdi clutch and flywheel
Offline scarr89
« Reply #7 on: 05 April 2012, 16:57 »
Steve is correct, I was wrong. The 115/130/150 6 speeds are the same size, 240mm flywheel I think  :lipsrsealed:
Offline darren1.8t
« Reply #8 on: 06 April 2012, 06:48 »
thanks guys for your help  :wink:
