Author Topic: Had enough, its going !!  (Read 7221 times)
Offline justalex81
Re: Had enough, its going !!
« Reply #30 on: 18 April 2012, 18:37 »
how much did you pay for this sh1thouse?
Offline markswan
« Reply #31 on: 18 April 2012, 22:53 »
bloody 700 quid, wish I hadn't bothered now.
changed the oil and filter tonight, someones just pointed out that some non gen crank sensors dont work too well, so i'm prob going to have to change that too..
It will run sweet as anything when i finally get it working as everythings been done !
Offline markswan
« Reply #32 on: 24 April 2012, 23:06 »
been to a vw specialist today, hooked it up, and apparently its the hall sender, as the distributor is not in the right place (im a noob so this doesn't make much sense to me),
oh and apparently my breather pipes are buggered )
Offline clipperjay
« Reply #33 on: 24 April 2012, 23:14 »
Just read this thread sorry mate you sound like a good lad for this to happen but £700 you was better buying of the bay TBF. But hope it gets sorted fella!
Offline DubAndDubber
« Reply #34 on: 25 April 2012, 00:10 »
apparently the hall sender always pops up under diagnostic. I wouldnt worry to much.
Mk5 Golf Gti 06'
Offline markswan
« Reply #35 on: 26 April 2012, 23:43 »
bugger...
i'm not further forward with it..
still if anyone Lives nr Bolton i've found a pretty friendly VW garage
Offline chrisr103
« Reply #36 on: 26 April 2012, 23:47 »
If your only in Bolton then a friend of mine owns a VW specialist Garage in Royton
<a href="http://giffgaff.com/orders/affiliate/chrisr45" target="_blank"><img src="http://giffgaff.com/banner/01_80x15.png" width="80" height="15" alt="Get a free giffgaff Sim" /></a>
Offline shaft69
« Reply #37 on: 29 April 2012, 07:58 »
I work for BMW our older petrol engines have similar problem being crank shaft sensor. Ok till warms up when hot cuts out and doesn't start. They split and open up at operating temp ok when cools down a bit. Doesn't log any faults either, my old mk3 gti also had fault when driving car felt like cut out for split second when driving. When sold lad said would start that also turned out be crank sensor.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline danny_p
« Reply #38 on: 29 April 2012, 14:50 »
they'll run without the hall sensor.
on mk3's i view cranck sensors as a SERVICE item   on any of my customers cars if it has a cam belt it gets a cranck sensor ( unless its just had one)
all the VW's have gone bar 1.
Offline markswan
« Reply #39 on: 29 April 2012, 23:18 »
think this is a must have on mine then, they've replaced the crank sensor as the old one was touching metal, but might have used a non-gen or cheapo one..
sorry that the thread has turned into a workshop one.. but I really appreciate the help with this guys :)
