Author Topic: HelP please  (Read 1070 times)
Offline Low rider
HelP please
« on: 01 April 2012, 19:53 »
Right the problem is had ma mk2 running  after I did heater matrix blessing it up turned it off as  I needed to jack the car up and bleed the brakes  then went to start it and it won't fire .it has a alarm box underneath the header tank  bottle and it seemed that it had burnt some wires .
There is no fuel pump prime or spark but every thing else works
Any help wud be fantastic :)
C reg mk2 gti
K-jet
Offline JamesS
Re: HelP please
« Reply #1 on: 03 April 2012, 13:54 »
Likely to be the alarm wiring if it's burnt, especially as heater matrix piping is in this area, which is where you have just been working. The whole point in an alarm/immob is to cut power to injectors, plugs, starter or fuel pump, if wires are burnt then it's a likely cause for your issue. If it's a alarm/immob take it out to get the car going again or replacing it (this time keeping alarm module inside the car)
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
