Author Topic: Vr6 stem seals  (Read 1831 times)
Offline leigh_harty
  • Audi AGU
Vr6 stem seals
« on: 31 March 2012, 09:45 »
How do I remove them? Just a case of long nose pliers and a good yank?
Also refitting new ones, how do I go about this job properly?
Many thanks, Leigh.
Dont lose your dinosaur!
Re: Vr6 stem seals
« Reply #1 on: 31 March 2012, 10:36 »
Yes, they should just pull off.
The new ones should have a sleeve that goes over the top of the valve so that when you slide the seal down over it does not get damaged.
Offline leigh_harty
  • Audi AGU
Re: Vr6 stem seals
« Reply #2 on: 31 March 2012, 10:40 »
Cheers Wayne, I'll find something flat and tap them on gently.
Old vs new
Re: Vr6 stem seals
« Reply #3 on: 31 March 2012, 22:10 »
They look fooked :shocked:
Offline leigh_harty
  • Audi AGU
Re: Vr6 stem seals
« Reply #4 on: 31 March 2012, 22:52 »
I bent them with the pliers but they are regardless lol
Got them all on and the patience testing task of fitting all the collets on the top of valves  :smiley:
Offline Screech16v
  • MK3 20vt AGU
Re: Vr6 stem seals
« Reply #5 on: 01 April 2012, 00:09 »
Use a bit of grease to hold the collets in place while you release the spring  :wink:
Offline leigh_harty
  • Audi AGU
Re: Vr6 stem seals
« Reply #6 on: 01 April 2012, 00:24 »
Aye, I quickly learnt that  :grin:
