Cosmetic and bodywork matters
Black tailgate VW badge
Topic: Black tailgate VW badge (Read 2936 times)
j_s
Here all the time
30 May 2005, 20:56 »
Seeing as I have a black badge on the front I thought it would be nice to have a black badge on the back. The only place I found was on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=9889&item=4553207554&rd=1
He has listed loads of other VW stuff for all marks of Golfs but do you think that badge will be ok?
Edit: How do you remove the rear badge as well? In case my only option is to paint it
Last Edit: 30 May 2005, 22:46 by j_s
James
Organisys
Old and Slow...
Re: Black tailgate VW badge
31 May 2005, 13:01 »
Pull off clips in boot, behind carpet.
Gently pull badge off.
Clean everything up.
Spray badge.
Wait to dry 100%.
Stick badge back on with super glue!
Quote from: Mr Blue on 29 May 2013, 19:15
j_s
Here all the time
31 May 2005, 22:26 »
Thanks for the reply mate.
Whilst out looking over the car tonight I had a look at the clips, how exactly do you pull them out, is it with pliers?
James
Organisys
Old and Slow...
01 June 2005, 12:22 »
yeah, pull the little clips off from the inside of the car. I sprayed by badge a while back, i'll see if i can get round to uploading a pic for you.
j_s
Here all the time
01 June 2005, 12:50 »
Thanks mate, I want to try and match the front black badge as well as I can, not sure what paint to get hold of really.
James
Organisys
Old and Slow...
02 June 2005, 12:13 »
Just use any gloss black mate.
j_s
Here all the time
Reply #6 on:
02 June 2005, 16:53 »
Looks nice mate and thanks for the pic
Did you use a rough grade of sandpaper on the badge first?
Also did you not prime it first?
Cheers mate
James
Organisys
Old and Slow...
Reply #7 on:
03 June 2005, 12:19 »
i used a very fine grade of paper, and then cleaned it well with solvent, petrol, or acid wheel cleaner will do too. Then spray in fine layers, being patient between layers.
j_s
Here all the time
Reply #8 on:
03 June 2005, 20:48 »
Thanks mate
I'll get on with this once i've been over the stone chips and got my door builds started.
James
