Author Topic: High pitch noise under load  (Read 2655 times)
Offline Snoopy
  • Moderator
  • Geoff.
« on: 30 March 2012, 07:36 »
Standard GTI.
If i put my foot down in second or third theres a high pitch noise between 3.5-5K revs like a high pitch resonance.
Anyone any idea what it maybe?
The problem is i don't always drive this car and i cannot remember it been there before.  :undecided:
I have read about similar with induction kits, They talk about boost leaks maybe the cause, is this a common problem? If so could i monitor it with VCDS to check.
Anyone any ideas or is this normal once its a couple years old?
Thanks  :undecided:
Geoff.
« Last Edit: 30 March 2012, 07:42 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline mkviken
Re: High pitch noise under load
« Reply #1 on: 30 March 2012, 10:23 »
Mine didn't do that standard.
Wonder if the DV is split. They made a later version which was better but don't know if yours has it?
Golf GTI 7.5 230 white silver
Offline The Danno
« Reply #2 on: 30 March 2012, 14:40 »
That will be the Mrs mate. Remove before driving and the problem should go away.  :wink:
Offline Neil gti
« Reply #3 on: 30 March 2012, 23:04 »
^^^ :grin: yes my mrs makes that noise  :grin:
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #4 on: 08 April 2012, 16:57 »
06f 145 710g
That oil leak mine has seems to be coming from round were that actually bolts too from round the bolt / mounting surface nd its running down the pipe to were I can see it.
Only a slight weep but then again I have only used it twice since this month for only around 70 mile.
« Last Edit: 08 April 2012, 16:59 by Snoopy »
Mk6 GTI  &  Mk1 GTI
Offline mkviken
« Reply #5 on: 08 April 2012, 17:16 »
sounds like the diaphragm has split inside the DV
Offline mkviken
« Reply #6 on: 08 April 2012, 17:21 »
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #7 on: 15 April 2012, 07:56 »
I rubbed quite a bit of oil off that pipe and bracket before i took the photo.
Mk6 GTI  &  Mk1 GTI
Offline mkviken
« Reply #8 on: 15 April 2012, 08:50 »
is that pipe the oil feed for the turbo? if so and its that which is leaking i wouldn't use the car.
it sounds like its a knackered DV from your previous posts though.
thats a warranty job but they're cheap anyway if you wanted to do the work yourself
