Author Topic: speedo digital display led voltage  (Read 2045 times)
Offline sharki786
  • GOT BOOST??
« on: 30 March 2012, 00:53 »
Hi all,
i wanted to know the voltage of the leds that are inside well under the digital display in the speedo clock. I have seen some SMD's on ebay and they are rated from 1.1-2.2 v. I just wanted to know the max voltage im sure they are not 12v unless im wrong. I know kells might be able to tell me but his inbox is full lol.
Thanks peeps
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
Re: speedo digital display led voltage
« Reply #1 on: 28 April 2012, 01:25 »
thought id bump this up!
anyone?
*****MK4 GTI T*****
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 28 April 2012, 08:00 »
They are bulbs with a green film not LED's  They are 12v  so you would need a 12v LED,  they do however sell them on ebay in the correct bulb holder so its a straight swap.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline 16valver dan
  • 1.8 20v turbo MK4 Golf
« Reply #3 on: 28 April 2012, 10:42 »
t10 twist bulbs if i remember correctly from doing mine standard white because as stated the green film is what changes the colour cheap enough i bought my bulbs in a batch of 10 for 3.99 i think i can link you to the bulbs you need if you want?
il update the sig when i get a good photoshoot ;)
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 28 April 2012, 13:31 »
sorry people. its no the 2 twist lock bulbs im on about. im on about the SMDs under the 2 digital display units (shows milage & time)
*****MK4 GTI T*****
Offline b_boy02
« Reply #5 on: 28 April 2012, 15:08 »
Some units do have bulbs that light the LCD displays where as the later dial cluster units have the SMDs. Must be 12 volt SMDs I would have thought.
« Last Edit: 28 April 2012, 17:02 by b_boy02 »
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #6 on: 28 April 2012, 15:59 »
i have some at home ill check but think they are 12v
SMD chip leds are in all late clocks, anniversary and colour concepts for the Mileage and clock displays
much better brightness than the older bulb and filter types
Not no ordinary GTI....
www.mixcloud.com/kells/
