Author Topic: Stone chips and tiny areas of rust  (Read 2137 times)
Offline j_s
« on: 30 May 2005, 18:09 »
Hi guys
It's been a while since i've had to deal with a little bit of rust, but i've got some stone chips that have some surface rust, they are tiny though.
What's the best way to remove the rust from such small areas first before I apply the Jenolite (I think it's called) and primer?
James
kingsmk2
Re: Stone chips and tiny areas of rust
« Reply #1 on: 30 May 2005, 18:13 »
well u could try some t cut or similar to lift the surface rust, although to be honest if there is several of them id wait and get it painted m9 otherwise it will end up look abortion with loads of dots...
Offline The Hoax
« Reply #2 on: 30 May 2005, 18:15 »
I find that one of those little multi tools like a Dremel is excellent. You can pick up a cheapo copy for about £15 and that comes with all the grinding stones and discs that you'll need. It really is a great tool.
Offline Mr Blue
« Reply #3 on: 30 May 2005, 18:19 »
if they are just very tiny stone chips with surface rust you can get away with a mop and polish using G3 polishing compound. your local bodyshop could mop it for you on the cheap.
