Author Topic: Another Coilover Question.  (Read 1171 times)
Offline Hoggy
  • Mk4 GT TDI 150.
« on: 29 March 2012, 17:10 »
Seen a few threads like this but they weren't leading to my answer.
What i want to know is, I have a Gt Tdi and im going to be putting some fk coilovers on it, im running 18" r32 alloys, ET 35, 8J with 225 40 tyres on. Im only wanting to go 40mm so will i need spacers for my wheels? If so, what size?
Any advise welcome!
Cheers, Hoggy.
Offline AD1.8T
Re: Another Coilover Question.
« Reply #1 on: 29 March 2012, 17:13 »
Try it bud you most likely will need them but to save buying them first drop it to were you want it worst case wind it back up until you get some
Offline shaft69
« Reply #2 on: 29 March 2012, 17:24 »
I got same rims/tyres on my mk4 got 15mm spacers on rear. Fronts are ok but poss get 5mm on front.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Hoggy
  • Mk4 GT TDI 150.
« Reply #3 on: 29 March 2012, 17:31 »
Cheers for the quick replies guys, will do exactly that Ad! Is 15mm not a bit drastic to go at the rear?
Cheers, Hoggy.
Offline shaft69
« Reply #4 on: 29 March 2012, 18:32 »
Tyre top fits under arch rest of wheels doesn't is limit at 15mm mate. If going low 5-10mm i'd say.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Hoggy
  • Mk4 GT TDI 150.
« Reply #5 on: 29 March 2012, 18:37 »
Ahh right, if needs be ill go 5mm front and 10mm on the rear. :)
Cheers, Hoggy.
Offline cullygti
« Reply #6 on: 30 March 2012, 00:19 »
i got 15mm on rear and 5mm up front is a good set up as said and looks pretty good  :smiley:
Offline Hoggy
  • Mk4 GT TDI 150.
« Reply #7 on: 30 March 2012, 07:56 »
Do you have much trouble with wheel bearings going on the rear with such a wider set up?
Cheers, Hoggy.
Offline shaft69
« Reply #8 on: 30 March 2012, 08:25 »
No that's not wide to some people have it.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline cullygti
« Reply #9 on: 30 March 2012, 11:10 »
i aint had any probs yet mate  :smiley:
