Author Topic: PSI tuning stoke on trent  (Read 1879 times)
Offline shaft69
« on: 29 March 2012, 14:48 »
Psi tuning anyone ever used them, any good, reliable?? Thanks.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline barrym381
Re: PSI tuning stoke on trent
« Reply #1 on: 29 March 2012, 16:30 »
the guy i bought my 1.8t from used them an said he wouldnt go anywere else have loads of invoices for work they have done
Offline shaft69
« Reply #2 on: 29 March 2012, 17:00 »
Thats good to know not far from me, quoted me  £40+vat for stage2 map, already have stage1. Other APR dealers quoting £150-£250 for stage2.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Scott D
« Reply #3 on: 29 March 2012, 18:00 »
might be of some interest
http://www.psituning.com/page.php?xPage=statement.html
EDIT: just seen your other post below  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline shaft69
« Reply #4 on: 29 March 2012, 18:21 »
They still do APR spoke to them today!!  :shocked:
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline coxy1042000
« Reply #5 on: 29 March 2012, 18:34 »
they might hold some old stock and just want to get rid off it now thats y its so cheap plus if they dont deal with the company any more they might just be under cutting competitors
Offline shaft69
« Reply #6 on: 30 March 2012, 12:14 »
Still trying find out if car's worth stage2 map, i've heard stage2 APR map only after cat lambda sensor delete map if fitted decat or sports cat stops CEL light coming on. In process of finding out exactly what stage2 map entails, as different APR dealers give different story on stage2. so talking to APR usa themselves, You think all sing of same hymm sheet not the case.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline barrym381
« Reply #7 on: 30 March 2012, 12:20 »
get the car to r-tech  :wink:
Offline km
« Reply #8 on: 30 March 2012, 13:31 »
used them once. thought they had a great service. was still emailing me at about 9pm, trying to sort out some bolts and bushes. then put me first priority in the morning and emailed me first thing. order had been shipped out next day delivery and sure enough, i received it!
Offline shaft69
« Reply #9 on: 30 March 2012, 14:46 »
After all my whinging with APR today just found out awesomegti doing APR again range them stage2 map £60.
184 Wallgate, Wigan
WN3 4AL
07966492823.
